Sangro todo lo que escribo
A project log for The Grimoire Macropad
A macropad build that is probably more trouble than it is worth.
mrpendentmrpendent • 06/05/2023 at 02:38•0 Comments
So....neopixels, huh? Those things are tiny. Very tiny. On the first first board, I got the diodes installed, then the sockets, then 3 neopixels. On #4--SHENANIGANS!!
While trying to remove a messed up led, it actually peeled the solder pad AND the trace off the PCB.  So I had to start again. The second time, I carefully put all the Neopixels on first (thanks to some advice from Ben Heck):
Then the sockets...
Then the diodes, encoders, and headers...
I had one issue--the joystick holes seem to be 2mm (I think? Maybe 1?) and I don't have screws that size to mount it. so I got the pads ready, but can't mount it yet. I'm a little worried about it still, but fortune favors the foolish. I love the look of the diodes--the translucent red with black ends remind me of some of the carpenter ants that I would see back in NM.
Next up:
I'll be honest--I'm a bit scared of the last one. If it doesn't work after all this, I will be disappointed.
ps. Just a little image. Ignore this.
Nothing to see here.
