The DiskMaster64 is a small adapter that allows you to connect a Commodore 1541(II) floppy disk drive to your computer via USB. This enables you to read from and write to floppy disks. The adapter is equipped with a fast loading system that reduces transfer times. You can control the device using a command line interface or a graphical interface programmed in Python. The DiskMaster64 is a conversion of the DiskBuddy64 from the ATtiny to the CH552 microcontroller. This makes the adapter even smaller, simpler, and cheaper while retaining its full functionality.
