JP332A - 3.3V 2A stepdown voltage regulator
JP332A is a highly efficient voltage regulator module. It uses the TPS62A02 IC from Texas Instruments to achieve up to 95% efficiency.
0 followers
Introducing the JP332A voltage regulator - the perfect solution for powering your development modules and IoT sensors with ease and stability. With a fixed output voltage of 3.3V and the ability to handle input voltages ranging from 2.5V to 5.5V, the JP332A ensures your projects run safely and smoothly.
The JP332A is powered by the highly efficient TPS62A02 integrated chip from Texas Instruments, which allows the module to achieve an impressive efficiency of up to 95%. This means that the JP332A minimizes wasted energy, making it an environmentally-friendly solution for your projects.
Designed for hobbyists and professionals alike, the JP332A is compact and easy to use. With a small PCB that measures just 14mm by 8mm, the JP332A is perfect for integration into any project. The PCB also features holes for attaching a 2.54mm pitch header, making it easy to connect to your development modules or IoT sensors.
Datasheet_JP332A-ENGLISH.pdf
Adobe Portable Document Format - 1.01 MB - 05/02/2023 at 09:07
Preview
