When using the Raspberry Pi in an embedded system, make the SD card read-only to prevent system corruption. In this case, data such as logs and images cannot be stored. In this article, I will show you how to save data to this SD card.
Create a file system for data
Plug the SD card into a desktop Linux machine separate from the Raspberry Pi. unmount, resize, and shrink the root file system using Gnome Disks or similar. This will create a free space, so create a file system in that area with FAT.
Auto mount setting
After returning the sd card to the raspberry pi, edit /etc/fstab and set the file system for data to be mounted automatically.
pi@roktrack1:~ $ cat /etc/fstab
proc /proc proc defaults 0 0
PARTUUID=dc22932d-01 /boot vfat defaults 0 2
PARTUUID=dc22932d-02 / ext4 defaults,noatime 0 1
# a swapfile is not a swap partition, no line here
# use dphys-swapfile swap[on|off] for that
PARTUUID=dc22932d-03 /data vfat auto,exec,umask=000 0 1
Add the last line of the above configuration to your fstab. When you do so, modify PARTUUID to the ID of your environment. You have now created a persitent area on your read-only Raspberry Pi.
Convert to read-only
sudo raspi-config nonint enable_overlayfs
sudo systemctl reboot
After several dozen power-off tests, the system area was not corrupted and did not become unbootable. Files in the file system for data may be corrupted, but even partial corruption of data such as logs and images will have only localized effects.
