Hackaday.io Hackaday.io
Sign up Log in
GameToy
Just for fun... PicoW - 2" LCD w microSD
saulSaul
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
1 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
178
0
1
1
Team (1)
  • saulSaul
Join this project's team
ongoing project
This project was created on 05/09/2023 and last updated 4 years ago.
Description
Started a while ago and kinda forgot about it. I used games as much as I could for CS assignments, would probably have been good for round one....
The screen has a micro sd slot on spi, with wifi should mean enough storage space for multiple games with a basic ui launcher.
Gameboy layout looks nice but fitting buttons and a joystick in that space...
Might just split the controls from the screen completely.
decided a tiny pcb would help finish starting.
11 pins with 5v/3v3 in. gnd and 8 control pins for reset, backlight dimming, address select and sd card.
2.0 spi Display 320x240
https://www.adafruit.com/product/4311
Project Logs
Collapse
  • PicoW + 2" LCD Spi Display
    Saul • 05/12/2023 at 20:11 • 0 comments
    •  PCB = $ 0.91 2/3
    • LCD = $ 20
    • PicoW = $6
    • $27 Wifi Display!
    So simple I think it could be done full DIY on a mini CNC...
View project log
Log In/Sign up to comment
Sign up with Github
OR
first attempt at working with touch displays using FPC connectors, touch IC's and SD-Card.
Project Owner Contributor
ESP32-S3 - Touch TFT display board
0x0630ff0x0630ff
A PCB that adapts a standard DVI connection (+USB, +Power) into the now obsolete Apple Display Connector
DVI 2 ADC Converter
chris-tullyChris Tully
BK7258 is connected to 2x2.16" 480x480 AMOLED, one L1+L5 frequency band GPS module, and one SIM7670G 4G module. And 4 sensors.
Triple M33 low-power portable display
eleclabElecLab
Hacking SSD1325 OLED Display for use in custom projects.
SSD1325 OLED Hack
sidsinghsidsingh
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "GameToy", please tell us the reason.
Send message
Remove Member
