Fixing a vehicle floor mat, redux
A project log for The Technique of Laser
Laser cutter usage notes
peter-walshPeter Walsh • 12/01/2022 at 18:33•0 Comments
Summary
Fix the hole in your car floor mat.
This is not really a hack, just an odd use for a laser cutter.
This is the 2nd time I've had to fix this mat. The first time was seven years ago, and since then the repaired section has itself worn out and needs replacing.
The problem
The floor mat in my truck has a hole, right under the gas pedal.
The solution
I noticed someone on Craigslist had brand new toyota floor mats on the "free" list. Apparently the new mats came with a used vehicle they purchased, and they didn't need the mats. So for the price of driving 10 miles I got some "new carpet" stock for repairing my own vehicle carpets.
The new hole in my mat was on the edge of the original hole (the newly worn section was on the border of the original mat and the repair carpet), so in retrospect the original repair was off center a little.
To compensate, the new repair will use a larger cutout.
Step 1: Debriding
Center the laser on the carpet pad, and cut out a 150mm circle.
Step 2: Make a replacement
Cut a similar hole in fresh carpet
Step 3: Apply carpet tape
Using carpet tape, fix the newly cut replacement to the original pad.
Step 4: Final results
I don't really care that the color doesn't match my original pads exactly, it's just nice to have a fresh piece of carpet under my foot. Seven more years of use on that carpet!
