Case Optimization
A project log for MicroPort
USB-CDC Serial port for PIC18F, in under 1KiB. Refactored down from a USB-DFU bootloader, hand written in assembler to be light and fast
jesseJesse 12/31/2016 at 20:280 Comments
While reviewing the new code for identifying which descriptor is being requested by the USB host, I noticed that instead of using the Switch/Case macros I had instead manually implemented the same mechanism of using XOR and conditional branches. "Why not be consistent?" I thought to myself, and set about converting it into the Switch/Case pattern.
While using the macros cleans up the code appearance, and gets rid of some labels... it also increases the code size by a few bytes. Reviewing the reason why, I found that the 'default' case at the end of the block imposes 2 extra branch instructions. And in this specific scenario, the code inside the default block in this example is a branch to the setup_error code. This means the default block is literally 3 branches, when ideally it could be 1.
I looked at the other switch blocks in the code, and found 2 other cases of a default block that contain a single branch. Crafting a specialized case macro that includes this branch, instead of requiring a separate default block, will shave 4 bytes off of each case. It's a little ham-fisted for general use, but for the purposes of the 1KB challenge, seems like a win.
So, instead of this:
CASE    SOME_VALUE
    DO_SOME_STUFF
DEFAULT
    bra somewhere_else
ENDSW
I'll wind up with this:
CASEELSE    SOME_VALUE, somewhere_else
    DO_SOME_STUFF
ENDSW
And in the process, clean up the descriptor lookup code as well as save 4 bytes per altered statement.
