Took the time today to hook up two chips running the firmware and do some bandwidth testing. I have to say, I'm pretty impressed.
Testing consisted of sending a 3MB file of random data through 2 chips, and using WinMerge to compare the files. I've been testing on my machine using RealTerm to send and capture the data, but noticed an issue where even at higher bitrates the throughput wasn't increasing. Google to the rescue.
Turns out, the version of RealTerm I was using had a known issue where transfers would max out near 15KB/s, and all I had to do was download an updated version.
Transfers are very reliable up to 2 megabits per second with both chips on different USB endpoints. At 3 megabits however, I start to see what appears to be byte mangling. As the errors often appear to be bit errors localized to a few single bytes, this seems to indicate that the loss either due to noise on the serial line (about 12cm of breadboarding wire) or else a manifestation of the clocks of the two PICs being slightly out. I might be able to run both off of a single clock to test that theory, as well as pairing the serial connection with a twisted ground to try cut out noise.
The clocks are suspect, as both chips are using PLLs to kick up the frequency to what's required for USB full speed operation. One chip has a 24MHz oscillator, and the other has a 20MHz crystal resonator. The PLL in particular might be making the chips more sensitive to clock problems, but running both chips of the single 24MHz oscillator should be simple enough as long as the wires aren't too long. Call me lazy, but I don't think I'll relocate one of the PICs to shorten the clock traces to test a theory.
These speed tests have only been half duplex as well. At higher speeds, RealTerm seems to jam up on one side. That is, it seems like it's RealTerm jamming up based on the two instances I run becoming non-responsive after initiating the test. (It's not my code! I swear!) I might have to try sending between two PCs, as it seems to be related to running two instances of the program on the same PC.
Also: while it puts the firmware over 1KB, I'm actually testing with RTS/CTS currently. With the deadline looming, I've yet to decide if I'll be dropping that feature or not. Maybe I can squeeze another 50 bytes out. I think before I open that can of worms, I'll write a couple more logs going over what I've removed to make the firmware fit. The source is littered with code commented out, and once I pay tribute to the fallen opcodes, I can proceed to remove them and publish the code.
So, yeah! 2 megabits per second sustained transfer speed! not too shabby!
