Install openai and put your api-key in script ;
openai.api_key=" "
GPT options :
- open : vieuw image in browser.
- exit : close script
- print : vieuw image URL.
- get : download generated image and saves it like "picgpt.png" file.
- new : generate new image.
wils Nico
Aditya Singh
Neil K. Sheridan
likeablob
Ezu
OpenAI Image Creator script is a tool developed by OpenAI that utilizes the power of AI to generate images based on textual descriptions. It leverages a technique called "CLIP" (Contrastive Language-Image Pretraining) to understand the relationship between text and images. By providing a prompt or a textual description, the script generates an image that corresponds to the given input.The script combines the capabilities of OpenAI's language model and a pre-trained image generator to create visually coherent and contextually relevant images. It can be used for various applications, such as generating artwork, visualizing concepts, or assisting in creative projects.It's important to note that the OpenAI Image Creator script is a powerful tool, but it may have limitations and may not always produce the desired output. Experimentation and fine-tuning of prompts may be necessary to achieve the desired results. Try this ChatGPT free and unlimited website: https://chatgptfree.ai/
