I was really happy with version 1 and yet, in the end I fell into the same trap as most of the Sci-Fi UI designers in PC games and movies do. All those “little” displays looked great, I had my hexagonal status indicators (nothing says Sci-Fi more like hexagons) but it was not easy to bring any meaningful content on the skewed “screen estate”. And skewed is a CSS
literal here.
There was also the thing that I redesigned version 1 inside out so much by now, and moved it around a lot in the house, that it started to fall apart and had to be taped regularly. Yes, the phun of the Primary Buffer Panel falling off happened several times.
![](https://cdn.hackaday.io/images/2340721694974151437.jpeg)
Version 2
I eventually stumbled over a hand drawn design of a VF-1 Valkyrie cockpit of the Macross
franchise while looking for inspiration for something with more “screen estate”.
![](https://cdn.hackaday.io/images/3199891694974290349.jpg)
I created a 3D model of the upper cockpit panel in Wings3D
where I started to shove around buttons and switches to my liking while keeping close to the original layout. This way I ended up with way more buttons (can never have enough) and get more “screen estate” out of the box while still maintaining a sane layout that would not be in the way of operating something with it later.
Eventually I started to build version 2 but this time with wood: https://hackaday.io/project/192860-primary-buffer-panel-v2
![](https://cdn.hackaday.io/images/6884261694974799901.jpg)
I also started a website to document both builds in more detail: https://SimPit.dev
