Current Objective: build a simple pressurized multi-nozzle sprayer setup to determine feasibility of spraying an assortment of different liquids through multiple nozzles with some consistency. Then attempt to cover an object with liquid (maybe paint) to determine overall feasibility of the project.
Went forward with a slightly different plan for the prototype. I decided to use something with a screw top so I could easily access the inside of the container. I am going forward with a PVC container, shrader air valve from old bike tube, 4 - 2gph mister nozzles, 1/4" hose with stiffening wire,
Build Notes:
- It would be simpler to move the stiffening wire outside of the tube. Can consider just taping it to the outside for the prototype. Down the road maybe consider a 1/4 tube inside a stiffer tube (like a non-metallic electric conduit)
- Need a bolt/nut style connection for both the tube and the air nozzle at the lid.
