Leaks at both the hose and shrader valve. I thought I could get away with the sloppy silicon glue seals but the container won't hold pressure. I am going to be upgrading today and replacing the shrader air valve with a 1/4" compressor male coupler and using barbed to thread connectors for the tube. Add a couple nuts and rubber washers and it should make a nice seal.
