My Thingiverse page for this project: https://www.thingiverse.com/thing:5155241
A tiny Arduino-powered USB joystick mouse with 3D printed enclosure and right and left click functionality
Arduino_Joystick_Mouse_Enclosure.stlEnclosure for a joystick mouse made from an Arduino Pro Micro, joystick module, and tac switch. Margins are tight, so recommend lightly filing the inner tracks of the enclosure, and/or the rough sides of the boards themselves to slide them in easier. The solder points on the Arduino also need to be low profile and facing inward, and the excess solder under the joystick board needs to be clipped off.Standard Tesselated Geometry - 13.37 kB - 05/24/2023 at 16:20 |
/* HID Joystick Mouse Example
by: Jim Lindblom
date: 1/12/2012
license: MIT License - Feel free to use this code for any purpose.
No restrictions. Just keep this license if you go on to use this
code in your future endeavors! Reuse and share.
This is very simplistic code that allows you to turn the
SparkFun Thumb Joystick (http://www.sparkfun.com/products/9032)
into an HID Mouse. The select button on the joystick is set up
as the mouse left click.
#include <mouse.h>
int horzPin = A0; // Analog output of horizontal joystick pin
int vertPin = A1; // Analog output of vertical joystick pin
int selPin = 3; // select button pin of joystick
int rclPin = 2; // select button pin of joystick
int vertZero, horzZero; // Stores the initial value of each axis, usually around 512
int vertValue, horzValue; // Stores current analog output of each axis
const int sensitivity = 100; // Higher sensitivity value = slower mouse, should be <= about 500
int mouseClickFlag = 0;
int rightClickFlag = 0;
//int invertMouse = -1; //Invert joystick based on orientation
int invertMouse = -1; //Noninverted joystick based on orientation
void setup()
pinMode(horzPin, INPUT); // Set both analog pins as inputs
pinMode(vertPin, INPUT);
pinMode(selPin, INPUT); // set button select pin as input
digitalWrite(selPin, HIGH); // Pull button select pin high
pinMode(rclPin, INPUT); // set button select pin as input
digitalWrite(rclPin, HIGH); // Pull button select pin high
delay(1000); // short delay to let outputs settle
vertZero = analogRead(vertPin); // get the initial values
horzZero = analogRead(horzPin); // Joystick should be in neutral position when reading these
Mouse.begin(); //Init mouse emulation
void loop()
vertValue = analogRead(vertPin) - vertZero; // read vertical offset
horzValue = analogRead(horzPin) - horzZero; // read horizontal offset
if (vertValue != 0)
Mouse.move(0, (invertMouse * (vertValue / sensitivity)), 0); // move mouse on y axis
if (horzValue != 0)
Mouse.move(((horzValue / sensitivity)), 0, 0); // move mouse on x axis
if ((digitalRead(selPin) == 0) && (!mouseClickFlag)) // if the joystick button is pressed
mouseClickFlag = 1;
Mouse.press(MOUSE_LEFT); // click the left button down
else if ((digitalRead(selPin)) && (mouseClickFlag)) // if the joystick button is not pressed
mouseClickFlag = 0;
Mouse.release(MOUSE_LEFT); // release the left button
if ((digitalRead(rclPin) == 0) && (!rightClickFlag)) // if the joystick button is pressed
rightClickFlag = 1;
Mouse.press(MOUSE_RIGHT); // click the left button down
else if ((digitalRead(rclPin)) && (rightClickFlag)) // if the joystick button is not pressed
rightClickFlag = 0;
Mouse.release(MOUSE_RIGHT); // release the left button
}</mouse.h>Print enclosure and file down inner tracks so that the joystick PCB slides in easily
De-solder pins from joystick breakout board
Use wires to make the following solder connections:
Solder GND on Joystick to GND on Arduino
Solder 5V on Joystick to VCC on Arduino
Solder VRX on Joystick to A0 on Arduino
Solder VRY on Joystick to A1 on Arduino
Solder SW on Joystick to Pin 9 on Arduino
Solder tac button to Arduino using GND and Pin 2, insulate with heat shrink tubing
Connect Adruino to PC and upload code using Arduino IDE
Disconnect and reconnect Arduino and it should be detected as a mouse input
