I was really bothered about the frequency response, so I decided to take some measurements.
I used REW (Room EQ Wizard), and got a very flat response for a direct cable.. but a (I think) quite bad for my mixer :(.
(blue is -48 dBFS, pink Phase)
I will try to get more adequate Op Amps, and maybe tweak the dc coupling.
Also somehow I think I do not output enough volume... and I used 15 volts for that.... so maybe I will have to redesign it all?
Suggestions are appreciated!
