Basically an Arduino Uno/Nano combined with a boost converter, high voltage serial shift registers, and I2C RTC to experiment with VFD tubes
Tiny_VFD_Supply.inoATTINY Firmware to closed loop control boost converterino - 2.99 kB - 05/31/2023 at 15:54 |
VFD_Experimenter.inoATMEGA demo program to write serial characters to 16 character 14 segment VFDino - 8.10 kB - 05/31/2023 at 15:53 |
VFD_dev.schsch - 1.74 MB - 05/30/2023 at 19:04 |
VFD_dev_2022-04-26.zipx-zip-compressed - 440.58 kB - 05/30/2023 at 19:04 |
VFD_dev.brdbrd - 235.00 kB - 05/30/2023 at 19:04 |
So there ended up being a few issues with v1.0 of the VFD Experimenter. The biggest was that the h-bridge chip I selected to drive the filament with squarewave AC ended up not working as I expected so I ended up hot wiring it for simple dc drive with a current limiting resistor. The second issue was the components for the boost converter are a bit undersized (and thus why the multiplexed tube shown in the video was dimmer than I would have liked). Other than these two pebcaks though the board was pretty useful for experimenting with different random VFDs I pulled from various appliances.
