Gluing the tip
A project log for Atomic Force Microscope - from ground up
The aim of this project is to make high grade DIY or turnkey AFM.
100dollarhacker100dollarhacker 07/06/2023 at 19:200 Comments
Once we have quartz fork, we would like to glue Tungsten wire.
The problem is that it's extremely difficult to glue something so small. The easiest solution was to use syringe.
Now is just a meter of retracting Tungsten wire back put some glue on tip of the wire. Push wire forward and wait for few hours.
After couple hours of  drying up, we get
