As mentioned in my earlier log, the last rejection test was a bit flawed. Here’s my second attempt. Unlike before there won’t be any AC signal injected on top the common mode, just a DC offset. This offset is supplied by an isolated lab bench PSU. See my test setup below.
![](https://cdn.hackaday.io/images/8007801686432737074.png)
In this circuit the “Common Mode Switch” is what enables the common mode voltage. While this switch is open, a light pull-down in the CSA should essentially remove all common mode voltage. When the switch is closed (which I will do by clipping CH2 GND to DC-), the CSA will see the full common mode voltage riding on top of the 30ohm resistor. Here’s my actual setup….
![](https://cdn.hackaday.io/images/348451686432834410.jpg)
None of my tools are particularly precise/accuracy so it’s somewhat the blind leading the blind when it comes to these results. Nevertheless, these results are valuable in a comparison to one another... Note that I calculated the expected current using the CH2 mean divided by the measured resistance of the 30 ohm load (29.2ohm).
![](https://cdn.hackaday.io/images/4127791686432910154.png)
Ok so the error added by common mode voltage is less than ~1%, at approximately 286uA/Vcm. I’d call that a success.
