Revisiting plasma etching
A project log for Integrated Circuit decapping without acid
IC are amazing, but always closed in eopch which seems impossible to remove. Here we propose a method to decap without acids
quasi-scientistQuasi Scientist 08/19/2024 at 20:130 Comments
I didn't know how to control plasma, until I started to work with lasers. Two things I've learned first the white residue means it was too hot. Second, most Important, instead of power fan. I should use air pump just like laser does. With laser's air pump the air concentrated in very small tube, this way we may insure air/plasma is not too hot.
