Hackaday.io Hackaday.io
Sign up Log in
Triangle & Square Wave VCO Circuit
A simple VCO circuit that can be made out of generic components. Produces a very linear triangle and square wave output up to 20MHz.
customelectronicsCustomElectronics
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
2 comments
3 followers
  • Description
  • Details
  • Files 1
    • View all
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 2
View Gallery
Public Chat
847
2
3
4
Team (1)
  • customelectronicsCustomElectronics
Join this project's team
completed project
hardware
Oscillator vco analog discrete
This project was created on 06/06/2023 and last updated 3 years ago.
Description
A Voltage Controlled Oscillator (VCO) produces a waveform with a frequency that can be tuned by adjusting a control voltage. This VCO has a wide tuning range (adjustable range of over 750 kHz) with a maximum frequency of around 20 MHz depending on components selected.
Details
Files
Triangle Wave VCO V2_2023-06-06.zip
Gerber File for the PCB
x-zip-compressed - 18.98 kB - 06/06/2023 at 10:44
Download
Log In/Sign up to comment
Sign up with Github
OR
Timo wrote 06/10/2023 at 15:35 • point
Neat. I might use this in a Synteziser.
CustomElectronics wrote 06/11/2023 at 01:46 • point
That sounds like a cool project, I've been meaning to try making a some kind of synth for awhile now!
Portable 9V battery powered DC to AC converter with variable frequency
Project Owner Contributor
Palm-sized AC Generator
ellie-tEllie T
Beeper Circuit using Analog Components
Op Amp Alarm
jmpJMP
The 2015 Hackaday Prize
We start simple: with an open-source variable voltage power supply, which, for now, will use a modified computer PSU.
Open Source Bench Top Power Supply
acpcalinacp.calin
Moog style all-tube filter
Vacuum Tube Synth Filter
256byteram256byteram
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Triangle & Square Wave VCO Circuit", please tell us the reason.
Send message
Remove Member
