Hackaday.io Hackaday.io
Sign up Log in
Simple Forever LED Flasher
Basic 3 transistor LED flasher that should last around 10 years on a single CR2032 battery.
customelectronicsCustomElectronics
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
4 comments
2 followers
  • Description
  • Details
  • Files 1
    • View all
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 4
View Gallery
Public Chat
697
4
2
2
Team (1)
  • customelectronicsCustomElectronics
Join this project's team
hardware
ongoing project
low power led discrete components
This project was created on 06/07/2023 and last updated 3 years ago.
Description
This circuit pulses an LED at an adjustable rate (set by capacitor size chosen and charging resistor) ranging from several Hz down to once every few minutes or so. The flashes are fairly bright and can be noticed from many yards away in slightly dim lighting.
Details
Files
SMD Pulser No Boost Basic 5mm LED V2_2023-06-07.zip
Gerber Files for the PCB
x-zip-compressed - 15.49 kB - 06/07/2023 at 19:39
Download
Log In/Sign up to comment
Sign up with Github
OR
Ken Yap wrote 06/08/2023 at 00:31 • point
If you use blue or white LEDs they are much brighter but you'll have to use 3V cells because of the higher forward voltage.
aaaaaa wrote 06/07/2023 at 20:17 • point
add solar panel, and meybe real forever https://www.youtube.com/watch?v=KOZY5DXpZpY system . moving=electricity power
CustomElectronics wrote 06/07/2023 at 20:27 • point
Great Idea! I actually did that with a version of this circuit a year or so ago. That circuit used a solar cell from a calculator to charge supercapacitors during the day. It would last about 3 days after being charged in direct sunlight for ~30 minutes. Unfortunately I was never able to make the circuit operate by just using the solar panels to power the circuit directly using indoors ambient light, so I'll definitely be trying that next!
CustomElectronics wrote 06/07/2023 at 20:14 • point
Currently working on increasing the brightness of each flash of the LED without significantly increasing average current draw
catch the rabit in the dark garden
Project Owner Contributor
50Watt Led portable
michaelMichael
Official Hackaday Prize Entry
Simple circuit for light show
LED strip flashing to music
mattkomattko
1 to 1.6 Vdc led blinker
Led blinker
carbonosilciocarbono.silício
My E(I)llumination Project - and I can't spell
MEP LED
magicwolfiMagicWolfi
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Simple Forever LED Flasher", please tell us the reason.
Send message
Remove Member
