Hackaday.io Hackaday.io
Sign up Log in
Micro-LED Flasher Voltage Booster
Tiny LED flasher circuit used for decorations, indicator lights, and even as a faux after-market car alarm
customelectronicsCustomElectronics
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
0 comments
0 followers
  • Description
  • Details
  • Files 1
    • View all
  • Components 11
    • View all
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
Public Chat
174
0
0
1
Team (1)
  • customelectronicsCustomElectronics
Join this project's team
hardware
ongoing project
low power led
This project was created on 06/07/2023 and last updated 3 years ago.
Description
The circuit shown uses a CR1225 3v battery. Using this battery it lasts about 6 months. I use a variation of this circuit (with a larger battery) on the dashboard of my car as a faux after market car alarm. Basically the flashing mimics the lights on those car alarms in the attempt to ward off any would be robbers.
So far my car has never been broken into, and I choose to chalk that up to this little circuit and not the fact that I drive a 2010 Kia Rio!
Details
Files
SMD Pulser Final Fixed Vias_2023-06-07.zip
Gerber Files for PCB
x-zip-compressed - 14.14 kB - 06/07/2023 at 21:46
Download
Components
  • 1 × MMBT3906 Discrete Semiconductors / Transistors, MOSFETs, FETs, IGBTs
  • 1 × MMBT3904 Discrete Semiconductors / Transistors, MOSFETs, FETs, IGBTs
  • 2 × 2.2uF Ceramic Capacitor (0603)
  • 1 × 820k Resistor (0603)
  • 1 × 200k Resistor (0603)
View all 11 components
Log In/Sign up to comment
Sign up with Github
OR
Ni-MH battery charger which works from AC 230V
Project Owner Contributor
Ni-MH Battery Charger
discrete-electronics-guyDiscrete Electronics Guy
We can see the battery charge level
LI-ION LIPO1S BATTERY LEVEL INDICATOR
electronicabcElectronicABC
This circuit is used to be a polarity detector for batteries. You'll learn how to develop your polarity detector circuit using two diodes.
Polarity detector circuit
silcios-labSilícios Lab
My run through of Contextual Electronics cool Getting to Blinky KiCAD tutorial.
Getting to Blinky
jackson-keatingJackson Keating
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Micro-LED Flasher Voltage Booster", please tell us the reason.
Send message
Remove Member
