There is a very good IR Remote library for Arduino. This works with most controllers that work with Arduino. ESP32 has built-in remote peripheral. The library uses a timer and an interrupt pin to accomplish send and receiving IR signals. With ESP32 this can be done with the built-in Remote peripheral. Since the approach is entirely different it will be difficult to port the same library for ESP32. I have started writing one for the ESP32. The NEC encoding is working well.
#include "esp32_rmt.h"
ESP32_RMT rem1, rem2;
uint8_t cnt;
uint16_t cmd, addr;
void setup()
rem1.begin(17,1);
rem2.begin(16,1);
Serial.begin(115200);
Serial.println("Enter Commands");
void loop()
if(Serial.available()>0)
switch(Serial.read())
case '0': Serial.println("power"); rem2.necSend(0x3000, 0xfd02); break;
case '1': Serial.println("volume up"); rem2.necSend(0x3000, 0x7d82); break;
case '2': Serial.println("volume down"); rem2.necSend(0x3000, 0x7c83); break;
default: break;
This is my first port of Arduino Library, let's see how it goes. Any constructive feedback is much appreciated.
