Be aware that putting this together, even without prototyping expenses as the "end-user", will be more expensive than buying the MacBook Pro 16. This is a project for the passionate!
Below is a rough cost estimate in the configuration that I plan on using:
Sub-Total: $2504
Base laptop
- We do not need the first-party keyboard, trackpad, or screen, but buying only the required parts from the marketplace does not save us money over the DIY edition.
- Added benefit that you can revert to the first-party parts if the mod does not work out for you.
$1399 | Framework Laptop DIY Edition with Ryzen 7 7840HS |
$80 | 6x Expansion Cards |
$200 | 4TB NVME SSD (Amazon) |
$85 | 32GB DDR5 SODIMM (eBay) |
$60 | USB-C PD Charger (Amazon) |
Display Assembly and Palmrest
$300 | 3D-printed palmrest and display bezel pieces in ABS (outsourced) |
$100 | 1920x1200 14-inch matte IPS LCD (eBay) |
Keyboard
$80 | 110-pack Kailh Choc low-profile switches (Amazon) |
$70 | Full set of Kailh Choc keycaps (Aliexpress) |
$50 | Keyboard PCB(s) and supporting components (PcbWay) |
$10 | RP2040 Microcontroller (eBay) |
$20 | TrackPoint module |
