Estimated Bill of Materials
A project log for WorkBook (Framework 13 + Classic KB + TrackPoint)
Re-implementng the ThinkPad keyboard with mechanical switches and TrackPoint in the FW13 Laptop (Work-In-Progress)
kartoffelstolzKartoffelstolz 01/28/2024 at 20:500 Comments
Be aware that putting this together, even without prototyping expenses as the "end-user", will be more expensive than buying the MacBook Pro 16. This is a project for the passionate!
Below is a rough cost estimate in the configuration that I plan on using:
Sub-Total: $2504
Base laptop
$1399Framework Laptop DIY Edition with Ryzen 7 7840HS
$806x Expansion Cards
$2004TB NVME SSD (Amazon)
$8532GB DDR5 SODIMM (eBay)
$60USB-C PD Charger (Amazon)
Display Assembly and Palmrest
$3003D-printed palmrest and display bezel pieces in ABS (outsourced)
$1001920x1200 14-inch matte IPS LCD (eBay)
Keyboard
$80110-pack Kailh Choc low-profile switches (Amazon)
$70Full set of Kailh Choc keycaps (Aliexpress)
$50Keyboard PCB(s) and supporting components (PcbWay)
$10RP2040 Microcontroller (eBay)
$20TrackPoint module
