Version 1.10+ has an optional 4 digit identification number for access. A 4 digit PIN can be added from the setup screen and then when the sidecar boots up it will ask for the PIN before you can access the two factor tokens. An incorrect pin will reboot the device and ask again. The delay can be set in includes if needed.
Matt
