Apresys PDF/A Standard Description
10/10/2023 at 13:20 • 0 commentsAdded a detailed description of Apresys PDF/A Standard logger. At first glance it is very similar to Apresys Temp Trak, but the board layout and hardware are totally different.
Hackaday Prize Entry Video
10/09/2023 at 20:23 • 0 commentsHackaday Prize entry video has been updated.
Project Title Update
10/09/2023 at 20:20 • 0 commentsI removed the mention of "ARM" from the project title since Apresys board I added recently has MSP430 microcontroller.
Apresys Temp Trak Update
10/08/2023 at 18:02 • 0 commentsFinally I received my LaunchPad and managed to find an operational Mini USB cable since my last one appeared to be damaged (surprisingly, it was not easy, they are pretty much rare nowadays).
Now I could confirm that the pinout I posted earlier is correct. I was able to upload the Blink sketch from Energia IDE as you can see on the attached GIF. The embedded LED is connected to P2.1 (which is pin 9 in Energia IDE).
Q-tag CLm doc L Description
10/08/2023 at 12:01 • 0 commentsAdded a detailed description of Q-tag CLm doc L logger. At first glance it is very similar to the Q-tag CLm doc, but the board layout and hardware are pretty much different.
Apresys Temp Trak Description
10/08/2023 at 09:24 • 0 commentsAdded a detailed description of Apresys Temp Trak logger.
Testo 184 T3 Description
07/04/2023 at 18:53 • 0 commentsAdded a detailed description of Testo 184 T3 logger.
TempTale Ultra LCD Pinout
07/01/2023 at 20:23 • 0 comments[muttonchopsjoe] carried out some research and shared LCD documentation (1) (2) for TempTale Ultra Dry Ice, which is another modification of TempTale Ultra, but apparently they have similar LCDs.
Many thanks!
TempTale Ultra Description
06/29/2023 at 10:58 • 0 commentsAdded a detailed description of TempTale Ultra logger.
TempTale 4 USB Description
06/29/2023 at 09:47 • 0 commentsAdded a detailed description of TempTale 4 USB logger.
