Retro electric petroleum lamp
Petroleum lamp without petroleum, working with electricity and magic. (mostly electricity)
We had this wooden construction on the yard, with no light. But we needed light. So I made this lamp (after my father's tip). It looks cool, and it's fully functional and acceptable by modern scientific society.
More info on my website.
The lamp has a 100W 230VAC light bulb inside, connected with a 3*1.5mm cable. The cover is connected to ground.
  • 1 × 3*1.5mm cable Lenght is for you to decide
  • 1 × Light bulb socket For light bulb, obviously
  • 1 × Light bulb Gives light and wastes energy
  • 1 × Screws and stuff For mounting and etc
  • 1 × Beer
  • 1
    Step 1
    Drill a hole at the top for the cable.
  • 2
    Step 2
    Connect socket to the cable, insert bulb, and place them in the glass.
  • 3
    Step 3
    Put the glass to position, connect the ground, and pull the wire.
View all 5 instructions
