Simple but enough useful webradio by RTL8710
A project log for RTL8710 easy programming by Arduino IDE
Recent progress of WiFi modules does not need external MCU anymore. Now I just try to focus on ARM Cortex-M3 based RTL8710!
microwavemontmicrowavemont 06/09/2018 at 07:130 Comments
As presented, my recent board has 3.5mm Audio jack but I've not explained yet....
YES it works as webradio!!
Indeed a few months before, one acquaintance already let me know the webradio by RTL8710 but till now I did not check the operation, but surely it works very well!
The program and also compiled binary (in build/bin directory) is uploaded by Russian great programmer, pvvx.
After writing the file "ram_all.bin" by command (in the case of OSX)
cp ram_all.bin /Volumes/MBED/;sync
 Connect additional USB-UART to D6/D7 (in my board, I put characters "TXD" and "RXD") and
Connect speed of 38400bps-N-1 and push return to get command prompt, then write your SSID/password will start default web stream station. Other information (for example, station URL setting) is well described inthe above GitHub repository.
Actual operation can be found in the following movie... Have fun!
