This weather station was part of the Rezodo project. It has been moved to its own project as the Rezodo project was becoming too big to be easily readable !
This weather station is intended to be easily "tunable" to your own needs :
- transmission to the base can be done
- directly by the station itself if Wifi is available
- via Lora point to point to get a much greater range (currently working with more than 2.5 km between base and station)
- sensors can be choosen among the list and two major versions do exist
- wind only (+ sensors) for less than 50€
- wind + rain (+sensors) for less than 65€
The design of the two main versions is basically the same but the "mechanical" parts, of course, differ. We will cover the two versions.
As key specifications we propose these two long range wireless systems, with real time operation 24/24 7/7 and energy efficient solution, "off grid" and solar panel powered.
"Wind only" weather station
As I do belong to a RC flying club, we need to know the wind conditions at the airfield. These conditions are locally changing quite fast and weather forecast is not accurate enough for our hobby !
So I decided to design a "Wind only" version of the weather station.
Here it is, installed at our airfield
The airfield is far away from electricity network and at 2.5km from the first building where we have installed the Lora receiver.
Everything is working now and we have a public access to these nice gauges!
Last minute upgrade : The weather Station is now also fully integrated into windyApp weather forecast application.
The result is a very professionnal User Interface, merging weather forecast (top of screen) with local measurements in real time. That's really cool!
And you can even change the color code :
- green = good to fly
- yellow = warning
- red = too much wind you'd better don't fly
Wonder how to do this ? It's simple, follow this log : integrating your Weather Station with windyApp
Building this station is not complex. Read all this description and the logs and you will be able to build yours !
As you can see the wind sensors do work in very low wind conditions.
Price for this "Wind Only" weather Station including both emitter and receiver boards (GTW0 + GTW1) is less than 50€. Bill of Material is accessible here
Full weather station
This one is the most complete version, including all the sensors. It mainly differs from the previous one by the addition of a rain gauge.
The electronics goes inside the bottom box, wires go to the sensors into the pipes. PCB is protected against rain.
Here is a picture showing "exploded" view of the weather station:
And here it is during tests:
Weather station electronics
This schematics summarizes the electronics embedded into the weather station. The same PCB is used for the various versions of the weather station, and even for the Lora gateway 0 (the one simply equiped with Lora + wifi access + mains power supply).
In a few words, it has the following components:
- a lora module for long range communication between Gateway 0 and Gateway 1
- an ESP32 MCU + ESPNow (to be connected to Rezodo FDRS network if needed)
- a rain gauge equiped with weighing sensor for accurate measurement
- a wind direction sensor with a Hall encoder delivering 4096 angular postions (contactless... no wear)
- a wind anemometer with hall effect sensor (contactless... no wear)
- temperature, humidity, pressure, light sensors
More details into this log please read it as it contains important informations.
Components + mechanical parts for this schematics should cost around 65€. This price is for the "full" Lora weather station and does include the Lora GTW0 and GTW1...
To build the weather station you will have to add a few 3d printed mechanical components.
All the 3d printed parts are available on thingiverse (links on the left of the main page of this project). ...
JP Gleyzes
YJ
Manolis Nikiforakis
Nevyn
sparks.ron
Hi! I'm a beginner hobbyist and would love to build this project. I've already ordered the PCB from PCBWay (through the affiliated link) and a set of 3D-printed parts.
I'm having a bit of trouble understanding BOM_V2, though. The AliExpress links don't match what's available in Belgium very well, and some components are a little ambiguous. I'm unsure about things like capacitor package sizes, male/female pin headers and their dimensions, resistor packages, and the exact type of LDR needed,...
I'm currently trying to guess which parts to order, but I'm worried about getting components that won't fit or work correctly. Would it be possible to provide a more detailed BOM with package sizes, specifications, and perhaps alternative part numbers available from European suppliers?
I hope I haven't wasted my money on the PCB and 3D-printed parts! 😅 Any help would be greatly appreciated. Thanks!
