I haven't decided yet what kind of notifications I'm going to do when the laundry needs attention, but among the possibilities is blinking the LED on or both of the Sonoff S31 switches.
Doing the classic perpetual LED blink in ESPHome is simplicity itself. You just set up actions on the state changes to delay and toggle back and forth. This example uses explicit turning on and off, but it could also have use toggle actions.
switch: - platform: gpio id: me pin: number: 15 on_turn_on: - delay: 100ms - switch.turn_off: me on_turn_off: - delay: 1000ms - switch.turn_on: me
For this project, I want to be able to turn blinking on and off as a service call from Home Assistant. Further, I want Home Assistant to decide what the on and off periods are so it can do slow blinking, fast blinking, or some kind of asymmetric on/off cadence. So, the start_blinking service takes two parameters for those durations. The stop_blinking service has one additional job, besides just stopping the blinking. It has to restore the LED to the state it was in (on or off) before the blinking was started. Of course, that status was recorded when the start_blinking service was called. If start_blinking is called multiple times without an intervening stop_blinking call, the new cadence is set but the pre-blinking status of the LED is unaffected.
Here's the code (in two files) as it stands today. It has several other small changes since the previous project log.
substitutions: name: s31yellow friendly_name: Unknown Yellow Spirit alias_icon: mdi:cloud-question power_on_boot: 'true' use_address: ${name}.carpenter.org <<: !include { file: s31.yaml.inc}
and
# This is an adaptation of the ESPHome configuration for Sonoff S31 # smart plug described here: https://www.esphome-devices.com/devices/Sonoff-S31/ # Pin Function # GPIO0 Push Button (HIGH = off, LOW = on) # GPIO12 Relay and its status LED # GPIO13 Blue LED (HIGH = off, LOW = on) # GPIO1 RX pin (for external sensors) # GPIO3 TX pin (for external sensors) # This file is intended to be included from another file that defines # some configuration choices via substitution variables: # name: the name of this device, appears various places # alias_icon: front-end icon for the alias sensor # power_on_boot: boolean, whether to turn on the relay at boot time esphome: name: ${name} friendly_name: ${friendly_name} platform: ESP8266 board: esp01_1m on_boot: then: - text_sensor.template.publish: id: i_alias state: ${name} - if: condition: lambda: "return ${power_on_boot};" then: - switch.turn_on: relay else: - switch.turn_off: relay - switch.turn_off: i_blue_status_led globals: - id: IS_BLINKING type: "bool" initial_value: "false" - id: BLINK_OFF_PERIOD type: int - id: BLINK_ON_PERIOD type: int - id: PREBLINK_STATE type: "bool" wifi: ssid: !secret wifi_ssid password: !secret wifi_password use_address: ${use_address} logger: level: DEBUG baud_rate: 0 # (UART logging interferes with cse7766) ota: password: !secret ota_password api: services: - service: start_blinking variables: {on_period: int, off_period: int} then: - globals.set: id: BLINK_ON_PERIOD value: !lambda "return on_period;" - globals.set: id: BLINK_OFF_PERIOD value: !lambda "return off_period;" - if: condition: lambda: "return !id(IS_BLINKING);" then: - globals.set: id: PREBLINK_STATE value: !lambda "return id(i_blue_status_led).state;" - globals.set: id: IS_BLINKING value: !lambda "return true;" - switch.toggle: i_blue_status_led - service: stop_blinking then: - if: condition: lambda: "return id(IS_BLINKING);" then: - globals.set: id: IS_BLINKING value: !lambda "return false;" # The blinking doesn't actually stop until one or the other of these delays expires # so wait it out (plus a little slop) before setting the LED on or off. - delay: !lambda "return 20 + max(id(BLINK_ON_PERIOD), id(BLINK_OFF_PERIOD));" - if: condition: lambda: "return id(PREBLINK_STATE);" then: - switch.turn_on: i_blue_status_led else: - switch.turn_off: i_blue_status_led # The value never changes except on a firmware update, # so the update interval is never, and the value is # published at boot time. text_sensor: - platform: template name: "${friendly_name} alias" id: i_alias icon: ${alias_icon} update_interval: never uart: rx_pin: RX baud_rate: 4800 binary_sensor: - platform: gpio pin: number: GPIO0 mode: INPUT_PULLUP inverted: True name: "Button" on_press: - switch.toggle: relay - platform: status name: "Status" sensor: - platform: wifi_signal name: "WiFi Signal" update_interval: 120s - platform: cse7766 update_interval: 30s current: name: "Current" accuracy_decimals: 1 voltage: name: "Voltage" accuracy_decimals: 1 power: name: "Power" accuracy_decimals: 1 energy: name: "Energy" accuracy_decimals: 1 switch: - platform: gpio name: "Relay" pin: GPIO12 id: relay # I changed this from a status_led component to a switch component # so that I could control it independently of the boring status. # "inverted" so that it's normally off. - platform: gpio id: i_blue_status_led name: "Blue LED" pin: number: GPIO13 inverted: true on_turn_on: then: - if: condition: lambda: "return id(IS_BLINKING);" then: - delay: !lambda "return (id(BLINK_ON_PERIOD));" - switch.turn_off: i_blue_status_led on_turn_off: then: - if: condition: lambda: "return id(IS_BLINKING);" then: - delay: !lambda "return (id(BLINK_OFF_PERIOD));" - switch.turn_on: i_blue_status_led
