I just finished wiring up the keyboard and 5-way switches and wrote a bit of micropython code to test them. None of the 5-way switches are working, but all of the front keyboard buttons seem to work! I'm not sure, but I must have wired the diodes backward on the 5-way switches... Maybe I can fix this in software? I might need to re-make them.
Here's the test code I'm using to matrix scan rows/cols and print which buttons are pressed on the console
from machine import ADC, Pin
import time
ROWS = (2, 3, 4, 5, 17, 16)
COLS = (6, 7, 8, 9, 10, 11, 12, 13, 14, 15)
cols = [Pin(n, Pin.OUT, value=0) for n in COLS]
rows = [Pin(n, Pin.IN, Pin.PULL_DOWN) for n in ROWS]
all_buttons = [(c, r) for r in rows for c in cols]
def getValues():
out = []
for n, (c, r) in enumerate(all_buttons):
c.on()
if r.value():
out.append(n)
c.off()
return out
while True:
print(getValues())
time.sleep(1)
