Hackaday.io Hackaday.io
Sign up Log in
Flash NodeMCU firmware to ESP8266
Flashing NodeMCU Firmware to ESP8266 12-F Module. NodeMCu is an open-source firmware and development kit that hel
bikash-narayan-pandaBikash Narayan Panda
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.6k views
0 comments
136 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
1.6k
0
136
2
Team (1)
  • bikash-narayan-pandaBikash Narayan Panda
Join this project's team
completed project
Software
weargenius NodeMCU ESP8266 flash nodemcu to esp8266 LUA lua on esp8266
This project was created on 12/30/2016 and last updated 6 years ago.
Description
Flashing NodeMCU Firmware to ESP8266 12-F Module. NodeMCu is an open-source firmware and development kit that helps you to prototype your IOT product within a few Lua script lines
The chip first came to the attention of western makers in August 2014 with the ESP-01 module, made by a third-party manufacturer, AI-Thinker. This small module allows microcontrollers to connect to a Wi-Fi network and make simple TCP/IP connections using Hayes-style commands. However, at the time there was almost no English-language documentation on the chip and the commands it accepted.The very low price and the fact that there were very few external components on the module which suggests that it could eventually be very inexpensive in volume, attracted many hackers to explore the module, chip, and the software on it, as well as to translate the Chinese documentation.
Details
Log In/Sign up to comment
Sign up with Github
OR
Flashing MicroPython Firmware to ESP8266 12-F Module to let it programmable using Python.
Project Owner Contributor
Flash MicroPython firmware to ESP8266
This is a standard XBee breakout board for the Blue Giga BLE112 Bluetooth Low Energy (Bluetooth 4.0) module.
BLE112 XBee Module
clint-stevensonClint Stevenson
A tiny network interface providing AVB connectivity to various IO options including AES3, ADAT, Headphones, Microphones/Instruments, etc.
AVB/Milan Module
fabrafabra
Modular & portable high-density dry sEMG acquisition devices
CleverHand - EMG
aightechAightech
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Flash NodeMCU firmware to ESP8266 ", please tell us the reason.
Send message
Remove Member
