Too many degrees of freedom prevent positional accuracy at the nozzle tip. For example, the figure below shows a heat map of nozzle tip position error for different rotation angles at the same tilt angle.
![](https://cdn.hackaday.io/images/8283771693478634450.png)
Tilt 30 degrees, rotation 60 degrees
![](https://cdn.hackaday.io/images/3362971693478649048.png)
Tilt 30 degrees, rotation 240 degrees
The error varies depending on the angle of tilt and rotation.
