Before the sofab closes for summer, I had time yesterday to print one last pair of alternate shell designs a inject a pair of skirts. Time for assembly !
![](https://cdn.hackaday.io/images/2307061690637731058.jpg)
First, there is some flash to remove:
![](https://cdn.hackaday.io/images/5339311690637701529.jpg)
A knot, and this gives us the first shell designed for assembly without an elastic band:
![](https://cdn.hackaday.io/images/8921351690637450207.jpg)
We have a pair:
![](https://cdn.hackaday.io/images/5130731690637477886.jpg)
It's missing only the elastic band:
![](https://cdn.hackaday.io/images/2895691690637504736.jpg)
but the band is too short for the classic single-clip attachment so, I had to improvise a bit with two clips:
![](https://cdn.hackaday.io/images/4261131690637550676.jpg)
And this is a winner down to 10m on the first attempt :)
The lens clips need adjustment after the latest run of oversized lenses to improve fitting and water tightness. I will have to wait until sept 4th to be able to launch new prints at the lab.
