Unfortunately, I do not have enough time to complete the project by the Jan 5 < 1k challenge date so I must change the scope of the project so that I can complete.
The intent of this project was to create a Class D amp from an ATtiny85 using FILTERLESS (0% PWM at rest) topology; however, I'm having trouble with distortion at the zero cross, and I don't have enough time to diagnose and fix this issue.
I will be changing the scope of the project to use standard Class D methods (50% @ rest) which will require a filter on the output end. :(
