Open source code:
You can find the source code here :
- GitHub link: https://github.com/Gleyco/UltraTower_KMP
- Works with the new ESP32 code: https://github.com/Gleyco/UltraTower/blob/main/UltraTower_V2_auto_freq.in
Technical choice:
The app is coded with Kotlin Multiplatform (KMP). It's a library and set of tools that allow developers to create apps for Android and iOS, all using the same Kotlin code. I'd long wanted to try my hand at creating a cross-platform application using Compose and KMP.
The cross-platform Kotlin app is fully open source and available on GitHub. You can explore the source code, contribute to the project, and even use it as a basis for your own applications.
The application is under development at the moment, and includes disc settings, pH settings and thingspeak settings. Thermometer and EC probe settings are coming.
I wasn't able to test the code on IOS because you need a MAC to do so.
App screenshots:
![](https://cdn.hackaday.io/images/7504031696411177705.png)
Link to learn about KMP:
https://github.com/JetBrains/compose-multiplatform-template#readme
