Well, it's better to say 'Solder Mess'!
The board 'face' in the middle is worth a thousand words.
First ever try using solder paste and hot dryer gun.
A project log for Focus
A compact and standalone board, programmable via a simple Visual Language inspired by the normal electric schematics.
dude you put a bit too much solder paste on the QFP pins, you are going to get some solder bridges. That technique works but you should use a smaller nozzle. Also you may want to put more paste on the bigger pads. Finally, for manual reworks you may want to consider using a lower melting point paste like the Quikchip one, it's easier to work with if you're using a hot air gun to reflow the boards.
Thanks man for those, very very useful, tips! I'm really enjoying some of your projects. Are you from Italy as well?
Yes! Italian hacker currently based in France :)
Wait... OSHPark does MicroUSB plated slots?! I have been inflating them to round PTHs... Gonna try doing that some day!
Feel free to email support@oshpark.com and our support engineers can give you tips.
Yes, and they does it very well! I was worried too. Fell free to contact me if you want the eagle part library.
