I started work on a replacement for the regular speaker driver with a completely DIY driver.
At the moment I am testing out the voice coil design and then once that has been finalised I will move on to the magnet housing.
First tests of the voice coil sounded very promising but I will need to alter the design in order to fit more windings as they are currently only 2ohms and I don't want to decrease the wire gauge to keep assembly for children easier.
Jamie Matthews
