Now that we have a somewhat safer power supply setup, and a way to attach things they don't fall off, it's time to dig into the microcontroller stuff.
The first thing I had to do was figure out the slight wiring mess. Fortunately, the previous hacker labelled many wires. So it was largely a matter of cross-referencing those markers to the Node32 (ESP32 module) pinout and the respective LED boards. The sample test code helped a lot, since it had some info as well.
After that, I assembled a perfboard module.
However, realizing how much time it was taking and also finding out I'd have *much* more lead time to finish this all, I opted to design a custom board.
These days I really shy away from "one-off" hand-soldered solutions, especially with an open source, reproducible design like this. It makes greater sense to develop a board that can be shared with others, updated, and re-made if there's a failure of some kind.
I searched for a "Node32" Eagle CAD footprint. One came up, but as usual, it was a bit janky. It had the wrong pin spacing and nothing was labelled. The schematic symbol didn't label all GPIO pins, either. :/
Time to make my own..
I also designed a custom nice level shifter PCB for the 74HC245. Confident this will work great when it gets back from the fab:
Now it's onto making a combined board with the Node32. Ideally with a disaply and control output, and the necessary pin header or Ethernet connector. Some output plugs for voltage readings would be nice, too ;)
[To be continued....]
