I'm very close to prototype release! I need to do some final schematic Ref. Des. # checks this weekend and it should be good to go with a very high confidence of the prototypes working. I'm trying to check and avoid all the mistakes I've ever made before... I know it still won't be perfect but it will close!
I'll need to assemble the LEDs myself, and the core matrix of course. But I expect assembly is going to be lighting quick compared to Core64. The reduced component count makes a lot of things easier.
Component availability looks good for everything. Knock on wood. Digi-Key should expect to hear from me Sunday!
Andy Geppert
Sounds like very good progress :-)
