Core16 prototypes ordered!
A project log for Core16: Interactive Core Memory Made Smaller
Core16 makes it easier to get started weaving your own Interactive Core Memory. You can do a lot of fun stuff with it after it is assembled!
andy-geppertAndy Geppert • 08/28/2023 at 03:46•0 Comments
Finally hit the order button. I went with the quickest possible turn-arounds at JLCPCB, which means a bland green PCB. Makes a fine first prototype that is bound to get hacked up as I discover mistakes and make tweeks. It's already in production. And my Digi-Key order is in as well for the components I need to manually add to the prototypes (LEDs, Hall Sensors, battery pack). Here's the confirmation render for part placements that I received.
Looks good!
Next step is a simple 3D-printable battery case holder so it'll snap on to the back of the board.
