Using a canvas in Fusion 360, I drew up the start of the frame for the radio. I printed a sample last night, and I'm not confident I can fit everything in it without making it super thick... I might have to use some smaller lithium cells as fitting 2 18650's is going to make it into a brick (more than it already is!)
How good is that font matching by the way? Wow!
Taylor Hay
