TcMenu is amazing
07/10/2023 at 02:29 • 0 commentsI struggled with the UI for this for some time. I was going to try using this legend's process - by making all the screens in photoshop, however I remembered some good advice from ADHD superstar Zack Freedman, and I aimed to avoid scope creep and make a real MVP before taking all my attention span building gorgeous UI's.
Somehow I stumbled upon TcMenu - which is exactly what I was looking for! Similar projects were higher on the duckduckgo results for some reason, but few I found run well on OSX or Linux, (besides an embarrassing Windows7 VM I dont have any Microsoft in my life)
TcMenu seems perfect - and is advanced enough to allow a rotary encoder to enter 6 digit numbers (perfect for tuning to a custom frequency) and capable of deeply nested menus. To allow me to quickly tune to any one of the 80x UHF frequencies, 60x VHF frequencies, and however many other frequencies I program in, I'm thinking of using a structure like the following - and would love to hear any feedback or suggestions for more features!!
(forgive the odd highlighting...)
UHF_CH UHF_01-40 UHF_01 UHF_02 UHF_03 ... UHF_41-80 UHF_41 UHF_42 UHF_43 ... SCAN // sets radio to channel mode, channel 1, and then scans through the 127 channels in memory (not sure how to exclude VHF channels) VHF_CH VHF_01-30 VHF_01 VHF_02 VHF_03 ... VHF_31-60 VHF_31 VHF_32 VHF_33 ... SCAN // sets radio to channel mode, channel 80, and then scans through the 127 channels in memory (not sure how to exclude UHF channels) FM_TUNE 000.000 // user can set any frq SET_FRQ // tunes to above frq FM_SCAN // macro which sets UV-5R to FM, and then presses scanner button CONFIG MANUAL_CONT // allows for doing any function on the UV-5R that one might need to do by exposing the buttons directly UP_BTN DWN_BTN MENU_BTN EXIT_BTN 01_BTN 02_BTN ... SQLCH 03 // user settable number SET_SQLCH
But next step is to go out this arvo and buy a rotary encoder with a button, as I had to strip one out of an old LED work light to get this far
Genesis
07/08/2023 at 08:33 • 0 commentsso I’ve been playing with this for a few weeks now, and here’s a little clip of the initial tests.
I’m using an analog switch IC to simulate button presses on the Baofeng keypad via Arduino digital pins. As it’s a matrix, and my skills aren’t quite there to figure out how to get the Arduino to do this any other way, I figured 4x of these chips get me 20 buttons I can press, and then my code is simple. I have an Arduino function that sends a button press, and can call it like
buttonPress(1); buttonPress(2); buttonPress(3); buttonPress(menu); buttonPress(up); buttonPress(exit);
This will allow me to define an unlimited amount of channels on the Arduino, and then use a gui on a yellow oled display to just tune the Baofeng to whatever frequency I’d like (like a software defined radio)
I can also simplify the menus, making macros for changing squelch or activating the inbuilt flashlight, or scanning.
I’m currently working on the ui - and then will start soldering all the buttons to my board full of switch IC’s!
