QMK configurator is great, but requires your keyboard to be in the grand list. For 100% custom designs, you have to put a bit of effort into it. This is the workflow I use.
Step 1: Develop the layout here:
http://www.keyboard-layout-editor.com/
Key labels are handy but not necessary.
If you need a keyboard plate, you can pop the output into this handy site:
http://builder.swillkb.com/
and you get a cad file suitable for laser cutting or, with a bit of effort, 3d printing.
Next, hop on over to here:
and use it to assign actual key functions to the layers. Unfortunately this bit of software is very out of date, a bunch of keys are missing and most of the fancy keys such as LC don't work when you try and import them. It's still quicker and easier to get a rough layout than to do everything by hand.
Once you have the keyboard layout go to settings, then save configuration. This will give you a JSON file that you can import into the QMK command line suite with
# qmk import-kbfirmware <name of json file>
you can then go into the keyboards/<keyboard name>/layout folder and edit the default.json to fix or add whatever features are needed
