Now that i have the screen in hand and can get an idea of exactly where everything goes, it's time to work on the top plate.
Had a few prototyping blocks around, so will be using those to access 5V, 35 and ground on the fat block and various to be determined and hopefully swappable lines on the skinny one, hole on the bottom right is for the USB hub, and the big hole in the top left is for the headphone jack, little holes below the monitors are for LED's
Rev 1 didn't have the depth to fit the raspberry pi, rev 2 is on the printer right now:
