test print on the bottom half of the deck, which is designed to hold the keyboard, mouse and a videogame controller. The keyboard case was the wrong size and the whole thing was about a cenimeter too short. Remeasure, reprint and move on.
width was due to me accidentally not replacing the default with the proper variable, keyboard outline was due to using the wrong revision of the keyboard, Onshape is handy but not being able to integrate it into my normal version control is a headache
