Over the time, as I was using Cyberdeck, I dropped the case, and LCD came lose. Thats not good. So, I redesigned the LCD mount, with screws.
With improved strength the LCD is more stable. I also routed the HDMI under the screen.
A project log for HAMDECK CYBERDECK
A Raspberry pi based simple, functional, and multi-tasking cyberdeck optimized for outdoor adventures.
