IT WORKS!
A project log for Stargate LED Clock
An LED clock using the adafruit 1/4 sections to make a 60 LED ring. Although not a new concept, it should be expandable to other variations.
david-hopkinsDavid Hopkins 07/16/2014 at 08:190 Comments
First prototype worked well (pic above)
only as a clock but you can get/set time from the serial port without issue
had a couple of issues, pinouts for the RTC, would be helpfull if the arduino site said they were ANALOGUE pins 4 and 5 for the two wire protocol.
currrent code uploaded, hours only show from 1-23, need to make that work over the whole 60 LEDS but its looking good
