In case you missed it: On the July 21 Hackady podcast Elliot and Dan were talking about our Laser4DIY project!
Lazzzor talk starting at min 29 :-)
Small correction on what was discussed on the podcast: our pump diode driver is running in constant current mode. We do not pulse the pump diode (yet). But yes, the magic of the q switch works with a cw pump diode too, and we indeed generate pulses ~2.5ns with almost 50kW peak
