When you are done with laser structuring the copper your PCB still is not finished. A proper solder mask is one of the thinks you'd want. Wouldn't it be nice if it could be done with a laser as well?
We did a quick test with a solder mask film (Bungard Lami). This film is meant to be used with a photo etching process, but maybe it can just be selectively removed with a laser?
We used a heat press to put the film on the PCB (usually a laminator is used), then put it under a UV lamp for a minute to cure, and threw it into a CO2 laser cutter. A couple of engraving passes at full power later revealed the bare copper. But the question is: is it complety removed so that solder sticks to it?
We wiped the board with isopropanol and hit it with a soldering iron.
That worked!
(These are solder pads with D=2mm)
Crips edges, takes solder well, very promising!
